- Aug 10, 2007
- HIGHLAND, MICHIGAN
i took some pics of the bearing surfaces in the axle, it looks like everyone of them spun but they were all pretty tight fitting when i was taking them out so maybe those are just marks from pressing?
this is hole for the outer pinion race and seal
this is the drivers side axle bearing hole
passenger side
heres the spiders and spacers and carrier races, i expected to find some thin shims on one side or both sides of the carrier, but there werent any?
heres a bent shock tab, probably from handling it after it was torched out at the junk yard?
some kind of casting number i havent been able to decode
AND HERES A BOX OF PUSSY! (her name really is Puss!)
i got the pinion gear pulled off, but the carrier is giving me alot of grief!
once i tighten the bearing splitter down it becomes the same size as the ring gear so i cant put the blocks under it for support.
ive started working on the specialty tools that will be needed to finish the install, so far ive figured out the pinion flange tool (pretty simple really, just drill a hole in the steel so the socket slides through and weld it in place so you can put a breaker bar with a cheater pipe in it, then drill the holes for the bolts to thread into the flange - and to think OTC wants $116 for this tool! it only cost $12 and my time)
i still want to make a case spreader, even if i dont need it, just because i like to make stuff!
passenger side
