rough country 4in lift
just a fyi, the rough country kit doesnt come with extended bump stops, you will want to get some for front. the rough country axle pivot bracket can crank a hole in your front diff pumpkin when to much uptravel is allowed..another members found that out the hard way...all you need is extended bump stops and the problem is fixed...
It does come with the peice to extend your stock ones. So it does have that covered.
where did you find the kit with the extended bump stops?
i bought mine from TopGunCustomz.com same price as the ebay one but i could use a creditcard instead of messing with paypal. that kit doesn't come with the extended bump stop... but i did see a pic of a guy that made one very simple. just cut a piece of rectangle tube and drilled a hole for a bump stop.. my stock ones are pretty beat up. guess i'll go buy some new ones somewhere.
I bought my kit straight from the company. Came with the peice to extend the stock bump stop up front.
