| Home | Forums | Tech Library | Resources | Magazine | Video | Truck Gallery | Shirts & Decals | Parts |
Ford 3.0L Camshaft Position Sensor |
By: Wicked_Sludge (Forum Member) Starting in 1995,
the 3.0L received a distributorless ignition system (DIS). This system
uses a set of positioning sensors, one on the engines crankshaft and one
on the engines camshaft, to determine when to fire the spark plugs. since
the oil pump is driven by the camshaft via the distributor on this (and
many "V" pushrod engines), Ford could not completely do away
with the distributor. The bottom half that engages the camshaft and drives
the oil pump would have to remain (less Ford redesign the entire block).
Since the bottom half of the distributor would have to remain anyway, the
easiest way to retrieve a camshaft position signal would be to mount a
sensor right on top of this "cam syncro shaft" (or Camshaft
Synchronizer). CMP SensorThe Camshaft Position (CMP) sensor consists of a permanent magnet, yoke and coil. The CMP sensor is positioned next to the cam gear. As each cam gear tooth passes the sensor magnetic pick-up an AC voltage pulse is induced in the coil. The PCM counts the number of pulses to determine the camshaft speed. The number of pulses counted in one second is the signal frequency. The Powertrain Control Module (PCM) uses the camshaft position sensor to manage sequential fuel injection and as part of misfire diagnosis. The PCM constantly monitors the number of pulses on the signal circuit. The PCM compares the number of camshaft sensor reference pulses and the number of crankshaft position sensor reference pulses received. If the PCM receives an incorrect number of pulses, Diagnostic Trouble Codes (DTCs) should be stored in the PCM. Some PCM systems will then default to multi-port or "gang-fire" injector operation. The camshaft position sensor signal is required to sequence the injector operation to the proper cylinder timing. If the camshaft position sensor or circuit is faulty, most engines will start. However, the PCM misfire diagnostic will likely be affected. On the 1991–94 2.9L and 3.0L engine, the distributor stator is the Camshaft Position (CMP) sensor, and it is a Hall effect magnetic switch. On the 1995+ 3.0L engine, the CMP is mounted on the oil pump drive assembly, located towards the rear of the block. it is also a single hall effect magnetic switch and it is activated by a single vane, and is driven by the camshaft. Oil pump drive mounted Camshaft Position Sensor Symptoms: There is usually (but not always) a squealing sound coming from the engine. Generally from the rear of the engine. It may also be that your engine just quit and displayed no oil pressure. What To Replace: You need to replace the whole unit (Camshaft Syncronizer & Camshaft Position Sensor). The camshaft syncronizer shaft has a nylon gear that engages the camshaft. This nylon gear wears out. If the gear wears out, it will stop turning your oil pimp. When that happens your engine will seize up. Do yourself a favor and replace it with a unit from Ford. They are the better than the one's found through the aftermarket. Location (1995+ Ford 3.0L): The the Camshaft Syncro Shaft (Camshaft Synchronizer) is on the top back passenger side of the engine. There is a holddown bolt (#3 in diagram below) that holds it in place. The Camshaft Position Sensor is attached to the top of the Camshaft Sycro Shaft. How The Repair Manual Says To Remove & Install It:Removal & Installation (1995+ 3.0L):NOTE: If the camshaft position sensor housing does not contain a plastic locator cover tool, a special service tool such as T89P-12200-A, or equivalent, must be obtained prior to installation. Failure to follow this procedure may result in improper stator alignment. This will result in the fuel system being out of time with the engine, possibly causing engine damage.
To install:
How Our Forum Members Say To Remove & Install It (1995+ 3.0L):By Forum Member fourwheelford: Disconnect the battery ground cable before doing the work. If you take the sensor off there is a little key that sits on top of the shaft. It spins and contacts the sensor. The opening (slot) where that takes place is where the key should be at TDC(Top Dead Center) on the compression stroke. If its on the exhaust stroke, the key will be to the opposite side of the slot. Use some whiteout and mark the placement before you remove the sensor so you can put it back on right. Put the motor at TDC. There is a small hold down bolt (10mm I think). Remove it and the sensor should wiggle right out. Replace it in reverse and make sure that the key stays in the center of the slot. Tighten the hold down bolt and put the sensor back and plug it in. The critical part is putting everything back the exact way it came off. It's a pretty easy job though. I did mine as preventative maintenance about 2000 miles ago. When I did it I used the harmonic balancer and left the spark plug in it. I cranked the motor by hand until I could feel the compression build up. Once I could feel the compression build up I set it to the zero mark (five teeth back from the TDC letters) on the balancer, NOT the actual TDC letters. When I removed the sensor the tooth was right in the middle of the slot. I lubed up the new syncroshaft and indexed the gear so it would go in into the same spot. I put everything back together and she fired right up with no CEL (Check Engine Light). The tool is really not needed. If you mark the 0 degree mark on the balancer with white out, and line it up with the CRANK positioning sensor (black sensor next to the balancer) on the compression stroke, then you will be at TDC. Install the syncro with the key in the center of the slot and with your line that you marked on the block or wherever and see how she does. Make note of where the key is before you pull it out. It will give you an idea of how far off you were. Connect the negative battery cable. By Forum Member Runnin'OnEmpty: Disconnect the battery ground cable before doing the work. If you look closely there's a mark on the crankshaft damper that's at 0* TDC. You may have to sandpaper the damper to see it, but it's there. It coincides with the fifth 'tooth' on the tone ring after the gap. To check for the compression stroke, just remove the cam sensor and see if the key and gap are close to being aligned. If so, then the engine's on the compression stroke. If they're almost 180* apart, then turn the engine over (1) revolution to get on the compression stroke. Remember the synchro 'key' and 'gap' won't be aligned perfectly, they'll just be close; (The key will be about 14* ccw from the gap, if I recall correctly). Connect the negative battery cable. From Forum Member fireant: I
just did a replacement of my Cam Position Sensor and Synch Shaft. Most
autoparts places have it listed as a Crank Angle Sensor... go figure.
Note From Wicked_Sludge: Just make sure the little flag on the end of the syncro, and the body of the syncro itself are both in the same orientation during installation as they were during removal. There's really no reason to set the engine to TDC before removal (unless your using fords special tool for setting CMP timing). Diagnostic Trouble Codes: Incorrectly installed gear driven camshaft position (cmp) sensor
synchronizer assemblies causing surge, loss of power, malfunction
indicator lamp on and diagnostic trouble codes P1336, P1309 and P0340.
