You should see what hooked up in my front driveshaft
Boggin
15+ Year Member
Facepalm?
Sent from hell using Tapatalk... on my iphone
What am I lookin at?
Sent from my HTC using Tapatalk
Looks like rear abs module
You will need to get a adjustable proportioning valve if you get rid of it.
I was gonna say, thats the proportioning valve/abs control.
How the hell did that happen?
Oh, bypass it. I did on my old 89 and never had a problem. Well, before it was froze up and never had rear brakes.
I took er up the road for a spin because she was parked since this summer, so I got up the road and when I turned around on the way back to the house as soon as I hit 5th gear I hear a big clunk and a scrubbing noise so I knew something was wrapped around the d shaft, so I got back home doing like 15mph and when I parked her I look and this is what I see, along with the wiring for the rear rock lights. I'll put her in the garage tomorrow and have a better look
Normally those are bolted to the frame..
Never needed anything of the sort here?:icon_confused:
I took mine out in 2004.... Used a brass connector between the two lines... Been running it since.
