yoke swap
Kevery
06/2013 OTOTM Winner
OTOTM Winner
Solid Axle Swap
Santa Cruz CA.
I need a 1310 yoke that will fit onto my 1350 bw. Is that possible? I have a 1210 on now (I think).
I assume this is for the rear output?
I would use the rear output flange assembly from a '88-'97 truck (t-case flange & 1310 driveshaft flange).
If you need an actual yoke, then one from the front of a 1354 case may be what you're after.
I need it for the front actually. guess I should have wrote that. I have the stock case out of my truck but it doesn't have the normal yoke on the front. do you think the rear yoke from the 1354 will spline up to the front of my 1350?
never mind! I'm and idiot. just remembered that the rear isn't a normal yoke. DUH.
Yea the 1350 has a slip-yoke front output.
Not sure if it's possible to convert the front to a yoke (a-la STX Highrider 1350) though even if so, you'd probably have a tough time finding parts to do it. Easiest would be to just get a '90-'97 1354 if you need a yoke front (it's a better case anyway, no internal u-joint).
Do you know what year or make truck I can get a cv off of that would bolt up to mine? thats my issue. My ujoint is maxing out. I have a cv from a 79 bronco but its to big.
Got what I needed. Thanks for the help. Tom woods flex joints are awsome!
No prob. Glad you got it figured out :icon_thumby:
