yet another 'name that' - mount?
rfl
Utah
When we pulled the engine out of a '93 Ranger 4.0L 4wd, the driver side block had a bracket above the left motor mount that extended over to the left frame rail. The end of that bracket has a small gas strut that mounts to another bracket on the outer part of the frame rail.
1) What is this gas strut/assembly called?
2) Do we need it?
I am thinking this is some type of torque damper that is all for feel and not to keep from braking the motor mount, but I want to be sure before I decide to not put something back on. The old gas strut has just about given out and the local parts stores are trying to tell me it is not stock - I know for sure its stock.
It is stock, and can be run without it. Best I can describe is it dampens the torque of the motor/helps the motor mounts live longer...
SVT
I second this post. It isn't "needed". I haven't had one since the swap. Almost exactly a year now.
That little shock is probably toast and if it is I'd be surprised if you can buy a
new one anyway.
They deleted it on the explorer going into 1993 because the ABS pump bracket mounted
to the set of holes the frame side bracket bolted to
Sorry for the late follow-up, but I did read the replies as they came in. We are not replacing the mount. FWIW, it is available from Ford, but not from any 3rd party that I have found (looked even though it was not going to be replaced).
