Xtra 2-3" of lift
DMW1985
I have a 03 4wd Ford Ranger Edge with a 4" suspension lift and a 3" body lift on it and the t-bar cranked. I was wondering if there was anyway to get an extra couple of inches of lift on it besides doing a sas. Would 3" torision keys and 2" shackles add the extra couple of inches or would that not work? I've searched everywhere and there's gotta be something out there to get that extra couple of inches besides getting solid axles and so forth. Any info is greatly appreciated.
'Fraid not. 4 + 3 is about it before SAS.
Why do you need so much lift? The front IFS axle will never support tires big enough to fit under all that lift.
you want more than 7 inches of lift? what are you needing to do with this thing!?
you go much higher without going wider and a stiff breeze will push it over. as is, I would be wary of driving it at road speed.
sounds like SAS is the way to go
