rangerbum
- Apr 22, 2008
- Age
- 33
- Kalispell, Montana
I need some clever thinkers. I recently had my axle grenade. The ring and pinion got chewed up. The ring Gear only lost a total of 7 teeth. The pinion had a total if 3 teeth LEFT.
As it was dying while driving the loss of teeth caused it to Buck sporadically at highway speed.
So after swapping in my new axle I drive it to work. It drives great, everything sounds perfect.
Pop the hood to check oil, motor is covered in oil. Dripping on the ground. But the level is fine. What should I look for? I can't find the leak since the whole bugger is covered in oil.
And sorry in advance for thread placement.
