spdcrazy
- Mar 8, 2008
- Age
- 37
- Homer, alaska
- mostly 86
kinda interesting.... how does this happen?
Is that a crack on the rotor? and dude, where'd your brake pad go![]()
Someone didn't assemble things right, that's the only thing I know for sure.
Actually I had that happen last week on a Brand new installation of rotors pads and a rebuilt caliper on my new explorer.
I drove it 50 feet from the mechanic and I heard a Thunk and brakes felt weird took it right back. It had folded over the spring retainer and the pad was half out of the caliper.
No idea how it happened. I can only guess that the pads bottom tab was not lined up correctly with the slot and the first time I used the brakes to stop it popped out.
bit of silicone on the offending pad since the retaining spring clip was toast and she was good to go. Pounded that side down a potholed dirt road to see if it would pop lose. and it hasn't yet.
So if you had OLD slider pins the caliper can be rocked back and forth and the pad can be worked lose.
