97BlackBetty
I too have been following the saga that this thread has become.
Im kinda interested in your idea thoug, it is something that i have thought about and would consider designing. In northern Michigan we have a lot of two tracks to tear down, my buddys Subaru flys and the only way for me to keep up is to make sure i swing the ass end wide, otherwise i roll it.
So i would like to help you and assist wth ideas, but dont knock em'.
Like said above you are gonna be looking most likely for an extended cab, 2wd. With this base i would probably look at bobbing the bed (shorten it, smaller yet), and as you stated you dont want to worry about pot holes or anything that gets in your way. 15 INCH WHEELS, alluminum alloy=light. Probably a tire in the 26-28 inch range, enough side wall flex and protection for your suspension and your wheels. They are also a small enough tire to keep your rolling weight low.
Suspension your gonna have to figure on your own, all i can say is HUGE swaybars. If i were to attempt it i would take a look at patoV6's truck, he used real soft springs which settled the truck low, and yet had large amounts of available travel. (Do a search on the site for his name and take a look at whats he did.) For shocks i would use a multi shock set up to better dissipate the heat. Keep in mind that for multi shock set ups you need to use smaller shocks.
An engine is gonna be to your discrepancy, in the tuner world its all about small displacement and high horsepower, but your wanting to use a truck for your base thats twice the weight if not more than any ricer. You need TORQUE! As has been stated before a big turbo diesel pickup will smoke most cars because of a simple thing called torque, however a diesel truck aint gonna take a corner at 35 plus, at least not well. I would use something like the 4.0 or a 302. Depends on what you have access to. For me its all about a 5 speed, the ability to choose your gears in an environment that can rapidly change is key, however an auto is generally smoother and faster.
Now im guessing looks are going to be important to you seeing as how your in an urban setting, hell their important tome and i take looks into account anytime i consider a mod, its my dd after all. Weight, as im sure you know is important, it needs to be kept low, so anything thats in their if you really want it to go fast has to be functional or it has to go. For me that means no stereo, not gonna fly in a dd so think about it before you put it in.
Thats all i have for now, if you got any questions go ahead feel free, got any ideas im more than willing to listen. The only other thing im wondering is what year your planning on using for your base, pre 97' would be my choice, i like the ttb in 2 wd and 4wd versions. The IFS may be more suitable for your knowledge base, its your choice in the end.
Justin
Justin
