Worth It?
Jonosranger
Firefighter
Bridgeport,Al
I found a 85 Bronco 2 for $550 Its a 2.8 5speed manual transfer case manual hubs and it runs started right up. Do you think it is worth it?
Worth It?
Well if it started right up ya. Although, i would invest a 200$ and get it checked from top to bottom by a trusted mechanic. He might find things that you don't see.
Sounds like a pretty decent deal for a running vehicle. besides body work, what else does it need? Motor sound okay? Does it move? Throw on a lift and wheel it till it breaks!!!
Yep it started right up and moved under its own power and yes the engine sounded great. No abnormal noises.Although the shifter was pretty sloppy. Probably just needs the plastic bushings replaced
congrats on your new toy.
how are the floor pans and cab mounts
I believe that they are fine. It is a southern truck.:icon_thumby:
