Woodys BII build-ish
those are $30 cheaper at your local parts store
but bad A none the less, i have a set i'm gonna put on my b2
i got them at the off road shop near my house...i'm just saying they came today
well its about that time again that the oil needs to be changed, but i have decided the go synthetic.
i've been thinking about going the same route since i just cleaned out the inside of the block, may do a motorcraft synthetic blend too
well went to the local pick-n-pull and got a couple things:
new visors:
this is a pic with the old one still on the see the difference:
and both new ones on:
then explorer leafs! lift is getting close i can taste it:
hows the mobil 1 workin out for you?
so far so good! haven't had any issues yet
I am liking this build!
good to hear, i was a little worried i'd blow up my little 2.9 for some reason
ya i was a little worried about doing the switch...im not a big fan of change...
but i like the synthetic so far!
Did you pull the springs at pick n pull or did you find some already removed?
they where half removed someone pulled out the back two bolt to remove the 8.8 so all i had to do was remove the last 2 bolt and i was outta there
Good lookin buid man. Its nice and clean.
It's wierd how Running synthetic makes you paranoid huh? You should be fine! Keep that ol 2.9 around for a while!
ya i dont know why i was paranoid to go full synth...but i like to have my 2.9 for a while longer =D
