Won't start
blademan7
Fuel pump not running, power to coil and injectors no power to pump. Engine light has also stopped coming on, used to come on at start and go off like normal. Replaced pump and relay, still don’t pump. Is this a ECM problem or something else?
did you check the inertia switch under the carpet passenger side and the eec relay maybe a corroded connector or bad relay try holding it while someone turns the ignition on you should hear feel it click.
Pulled my inertia switch with 3 guys in the cab. Replaced the pump and still didn't work till I looked under the pass side carpet.
