Wont start!!!!!!!!plz help!!!!
  • Thread starter Thread starter DC
  • Start date Start date
DC
U.S. Military - Active
Parkersburg WV
stock
31s
if it aint broke dont fix it if it is broke upgrade
my ranger wont start it will roll over but wont start
my plugs are good so aint the wires an i have a brand new efi on it the distibuter is good i have a new coil pack on it all fuses are good i think its the computer because my a/c an heater vents started poooring out water an i think it got the computer but i dont know for sure.
At first it would start but it sounded like it was missing or had a hole in the exhust system then i turned it off after returning home from work an then it wouldnt start at all plz if any1 can help me i would realy apreciate it this is my daily driver.
is the fuel pump turning in when you turn the key. I've had that issue twice now on two diffrent trucks. a new fuel pump relay and problem solved.
it could be the computer as well though... checl out rockauto.com. i think they were pretty cheap on prices there.
The fuel pump comes on I checked to see if it would spark but I got nothimg
id look into an ecu from a salvage yard then. at least price one out
Why don't you remove it and let it dry if it got wet. Maybe it's still good but I doubt it. It's worth a shot though. As a temporary fix you can also bypass your heater core if it's leaking with a short piece of hose.
i did remove it i set it out to dry took a hairdryer to it an pluged it back inwiggled some wire an it started
