The tags I have seen have the ratio beside the nut, not out in the middle. Also, I don't see any numbers ending in four. I do see a number beginning with four.
Lots of axles have two tags. One IDs the axle, gives the gear ratio, and has what I believe to be a serial number. The other generally specifies the type of lubricant to be used.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
