wLL 265/75r16 fit factory spare tire location?
ghunt81
Clarksburg, WV
I want to carry a full size spare on my truck. I heard a 32x11.50 doesn't fit under there unless it has low tread and they aren't the easiest to find a cheap used one of anyway, but I did read that a 265/75R16 will fit, can anyone confirm? I found both a fairly cheap used tire and cheap used 16x7 factory Ranger wheel that will suffice for a spare.
Sorry about the screwed up title, no idea what happened.
Get under there and measure from inside frame to inside frame. Most all tire companies will give the dimensions on tire size (actual heigth and so forth). It gets pretty tight in there when using bigger tires.
