Wiring some Fog lamps..Need a lil help
dmanmccann
foothills, NC
My buddy gave me some blue tinted fog lamps yesterday..There the kind from advance auto, ther like 6 in long by 1-2 in tall...I want to mount them underneath my REAR bumper between the bumper and hitch..
??? is i want the wire them to make em come on when i put er in reverse...Anyone know how to do this..
Also it has a keychain button i can press to turn em on, will this still work if I hook them up for reversing??
Ck and see how many amps the lights pull. You could overload your wiring in your truck. It could be done with a relay. I would just use the remote and keep them seperate from the truck reverse wiring if it were mine since you have a remote.
I was going to hook mine up to my reverse lights at first but then I decided to just hook them up to my switch panel because I had a switch not being used and I dont need the extra light every time I reverse. If you are stubborn just follow the wire frome your normal reverse bulb and tap into it with a relay. Good luck.
Alex
Well nevermind, found out after I checked the lights that one bulb was out and the other was too i beielve...I can replace the bulbs they are like permant or something, so i through them away but kept the replay box with keychain light turner on.
