gengerald
- Jan 9, 2009
- Automatic
Hello everyone,
I have a red 2000 Ford Ranger extended cab. I just got a Slacker G1 radio and want to get it hooked up with my truck. Before I start explaining, please excuse my level of knowledge. I have only put in two hours or so and I am still fresh to modding my truck. From what I have found, I will need a wired FM Modulator. My first question is, will my Ranger antenna input work with the “universal” input on most modulators? Also, do you have a suggestion as to what is a good unit? Next, I was planning on hooking it up for my cig lighter slot, not my AUX power slot, as I use it for my GPS. Will I need to buy a fuse or special components to get that hooked up? I understand I will not be able to use the lighter anymore, but I do not have a need for it. I am decent at soldering, but I am unsure if it is a simple male/female type connector. Also, would you suggest buying a dummy cover for it, or is leaving the lighter in it ok? I do understand that a new head unit is the best quality, but I am hesitant for two reasons. The first is I love my huge buttons on my stock single CD changer radio. Second, my budget is only $50 and most head units are $100+. Any suggestions or assistance would be great. I know I will also have to buy two “U” pins, right?, to pull out the radio and pop in the modulator. I appreciate you bearing with me in this. I am a bit nervous, as this is my first mod. Thank you for your time.
Gen
Gen
