Wiper motor not working
hmdboi1
Hammond, Indiana
1987
All right I need some advice my wiper motor in my ranger isn't doing any thing the switch works cause it clicks in the dash when you turn em on. Is there any way to change the motor out? Open to suggestions.
Use a test light or volt meter to make sure you are getting power to the wiper motor with the switch on. If so try lightly tapping on the wiper motor with it turned on. If you are getting power to the motor, then the motor is bad. Hook the test light to ground and check the wires to the motor, you should have current on different wires at different speeds. Figure out which is the ground wire and hook your test light to one of the hot wires to make sure the ground is good. If that all checks ok, then the motor is bad.
