Winter Project
fox408
Hey fellas, with winter quickly approaching, and more power on my mind, I've got the bug to do a V8 swap.
I have a 2003 XLT, short bed, 2.3, 5 speed, coil spring suspension.
Now, there are several things I'm unsure of, and would really like some help on. However, I have been reading as much as I can about these swaps for the past month or so, so I should be somewhat knowledgeable. Not asking questions like is an engine swap possible, or any of that.
I have had small v8 trucks before, first vehicle was a 1997 s10, with an SBC in it. It was a love hate relationship. Power - great, reliability - awful. So I have that in the back of my mind. I want to do this swap right, however, at the same time, I'd like to keep it somewhat of a budget build.
I want everything to work as factory for the most part. I do plan to keep EFI.
I'm currently on the market for a 1999-2001 explorer with a 5.0. I Plan to keep the engine, complete harness, rear end, and then probably scrap the rest of it.
Here come the questions...
1) Manual Transmission Use: I want to keep it as a standard transmission. My understanding is the two big options are the M5ODr2, which is basically just a beefier version of the ranger transmission, and it's in the f150. I like this option because it would allow me to keep my hydraulic clutch, and the slave would bolt right up (matching parts for the win) Sadly, I have heard that this transmission is somewhat weak, shift forks, synchros, etc.. I have no doubt that with the new found 5.0 power, I'll want to get on it every now and then. So, that scares me a little bit. People also say that the m5odr2 shifts somewhat sloppy compared to a t5. I'm curious as to whether a short throw shifter would help that any.
Speaking of a T5, that brings me to my next transmission option. The almighty T5 out of a mustang. I really like this option all except for the fact that they are cable driven... Would have liked to keep it hydraulic, but if it's the better transmission, perhaps it's the way to go for me.
Which would you all recommend? I'm open to go either way, advice would be awesome.
2)Pats Security System: The Explorer uses a PATS type B security system, and the Ranger uses PATS type E.
I would like to keep my ranger key, rather than swapping out the whole explorer ignition, that way I would have one key instead of a ranger key for the door, explorer key for the ignition.
3) A little bit nervous about this one.. Will I possibly be able to keep AC after stuffing a 5.0 in the truck? Haven't found much information on this.
4) I have seen tons of stuff about the explorer swap. As far as I'm aware the mountaineer is basically the same thing, isn't it? Should I broaden my search to a 98-01 Mountaineer as well, or do I need to stick with the explorer?
This is must the beginning, I'm sure there will be loads more to come. I appreciate your time, and look forward to hearing what you've got to say.
Thanks
Ex and mounty are the same. Sbf ZF 5 speed would be your answer. It is possible, but a tuner will likely be needed to delete the auto trans. A simple easy way to do this swap wiring wise is to just swap the dash harness, its only 7 bolts to remove the dash...
SVT
Correct me if I'm wrong, but from my short research, it seems as though the zf5 won't fit without a body lift of some sort? I should have mentioned, the truck is going lower, rather than higher. Hoping to end up with a somewhat street performance oriented truck.
A T5 can easily be run with an external hydraulic slave.
If that interests you, google it for a zillion options.
Plenty of room to keep AC if you use the Explorer accessories.
The ZF is more 4x4 oriented, like teddy said, the T5 is more street oriented and has been used over and over again, and works...
SVT
