Winter driving in a 4 wheel drive ranger / mazda
Personally I prefer to run an aggressive patterned all-terrain tire rather than a full snow tire. Maybe some day when I have more money I'll rethink that, but for now I'm content with my choice. Most of the time when it's too bad out for the all-terrains, I really don't want to be out there anyway.
I drove a 2wd Ranger for quite a few years in the winter and experimented a little. The stock all-season tires were absolute junk. I tried running a set of aggressive all-terrains in the front and muds in the rear for winter and had mixed success. In deep fresh snow it worked great. On anything else it sucked for traction in the back (but I noticed that the front tires did everything I asked of them). So I started running AT tires year round. I pick something on the knobby side with factory siping - I look for something that I can jam my fingers in between the tread and touch bottom.
When I finally did start running a 4x4 in winter, I was impressed with what it could do. I'd run around with the hubs locked in most of the time and the truck in 2wd (all of my trucks have manual front hubs). If I started to spin too much, I'd just give the magic lever on the floor a lil tug and away I go. Soon as it looks like I'm not going to need it any more, it goes back into 2wd. With good tires and a couple hundred lbs in the bed, I've found that at least around here I don't need to use 4x4 all that much and it's usually just something like trying to get started out on a hill from a stop.
I also carry a set of chains for when it gets really bad. And yes, I have used them before, not very often with a 4x4 though. But you have to keep your head about you, a 4x4 does not grant invincibility. I passed a lot of 4x4s stuck in ditches with my 2wd Ranger.
And when it's really bad and I need to go somewhere, there is always my choptop. I found that it'll go pretty much anywhere I point it in the winter, but it has some curious handling characteristics seeing how it's locked front and rear on some 33" bias ply tires.
As far as weight, use something like sand or salt. Never use solid things like logs, rocks, brick, block, etc. If you end up in an accident, those can become dangerous projectiles and they very well could end up in the cab with you. Matter of fact, I don't really care to have anything over about 5 lbs in the bed of my truck without something to secure it. I hate going around a bend or something and hear something moving in the bed that shouldn't be - shifting loads can cause accidents.
Glad I'm not alone. Everybody at hardware stores always look at me funny when I ratchet strap just a piece or two of lumber into place.
Everybody is spot on. I run an aggressive AT on my 2wd truck and didn't get it stuck at all last winter but I did have a few tough times...with 4x4 you should be fine. Just remember the old saying, two wheels gets you in, four wheels gets you out. :icon_thumby:
lol, glad to hear I'm not alone either. I've often had people make comments to me about tying something in. I had two guys harassing me about securing a lawn tractor in the bed of my F-150, telling me I shouldn't bother 'cuz it isn't gonna go anywhere. Well, it may not go anywhere if I drive carefully. But what if some idiot on the road forces me to make a more radical manouver? And if that several hundred pound lawn tractor shifts and provides just enough force to tip me? No thanks. I know of a guy several years back that got a bundle of 1/2" rebar, he had them set it in the middle of a lumber bar on a 10-ton dump, never tied it on figuring it would stay put because it was around 2,000 lbs of steel. Well, he went around a bend and it shifted towards the outside of the bend, pulled the whole 10-ton dump over on it's side and threw 20' lengths of rebar around like pick-up sticks.
Ever since I lost a 4x8 sheet of blue foam out of my Ranger (opened the cap door, slid it down into the bed and closed the cap door on top of it, figured it wouldn't go anywhere... lol), everything gets secured. When it looks like it's tied on tight enough, I throw another loop of rope or another strap on it, just to be sure. Haven't lost anything since.
