avid
- Nov 10, 2018
- Nebraska
- 4.0 V6
- Automatic
Hi everyone, the windshield wipers on my 98 Ranger are malfunctioning. They work only on the highest setting and they do not return to the parked position. Just started maybe a week ago and gave no prior indication of malfunction.
I tried a different multi-function switch and that didn't fix it. I tried swapping the horn relay (identical type) with the two different wiper relays in the power distribution box and that didn't fix it. I checked the fuse in the panel. What is likely happening here? Seems like a similar problem as I had with my ac/heat blower where that only worked on the "high" setting (and the solution there was to replace the blower motor resistor).
I have the shop manual but the pinpoint tests seem awfully complicated for what I suspect is a fairly typical issue.
