window removal
myranger26105
vienna, west virginia
was wondering how to remove the driver and passanger windows they are manual i took the door panels off and it looked like the window has 2 rivets at the bottom of the window that keeps it in the window track
this is on a 2003 ford ranger edge 4x4
Re: Window Removal
You will have to drill out the rivets and replace them with bolt, nut and washer when placing window back. You may have to remove the weather stripping around the window for the window to remove easier. Not that hard to do. You'll figure it out as you go. I replaced both my passenger and drivers side windows on my 1992 Ford Ranger over the summer. Good Luck.
