- Jun 6, 2009
Hey, figured Id dive in and get my winch mounted.
First, removed the bumper:
Then cut off the mounting brackets at the end of the frame rails...point of no return
no turning back now.
mock up:
I had bought a universal winch plate...then cut it to fit between the frame rails, and temporarily bolted up the winch.
This is where its going to sit, its off centered due to the winch motor being longer on one side, but I dont care...FUNCTION>FORM
I am mounting the winch on top of my front hitch receiver, that way I can unbolt my receiver and remove my winch if I want. I need to go get some steel today, some 1/4 " plate and some rectangle tube...then Ill mount it for good with a combo of welding/grade 8 bolts. Will post pics later tonight after its mounted.
-Nathan
mock up:
-Nathan
