Will this cause overheating?
i think i might go with a 4.0 rad since that would be easier to find, thanks
the three core 4.0 radiator is superior to the two core, that's what i'm running right now.
Yeah, find a 3 core 4.0 radiator. You'll know when you see it, cause it's freaking huge.
I'm running one in my 4.0 BII, and I very rarely even have to turn on my fan...
Is that a aftermarket only deal or do it come stock on 4.0 rangers or explorers?
I have never heard of one.
I am running a 2 core Explorer radiator with the aforementioned pusher and it keeps my 302 cool...
you need a radiator from a 91-94 explorer automatic with a/c. then you can use the built in transmission cooler for an oil cooler if you want. i think you just need the lower radiator hose for an automatic to do the swap. i did it on my truck.
Mine has this. I think they called it the "Heavy Duty Cooling Package". The fan clutch is also heavier duty.
It takes for-damn-ever to heat up in the winter, so I put a piece of .030 PVC plastic sheeting in front of half of the radiator in the winter.
EDIT: I just looked it up on Rock Auto, and they call it a "thick 2 row". Here's the description: "w/ 2 1/4 " Thick 2 Row Core; Fits w/o AC; w/H.D. Cooling; w/AC; w/MAX Cooling".
And a pic:
And a pic:
Won't fit a first or second gen without surgery.
I used one like this (turned out to be a leaker) It is the original factory radiator out of a 1994 Explorer automatic with A/C. Bolted right in my '85, second generation is the same.
As Beavis would say "well, I'll be damned". I thought it was in 98 they changed.
Thanks for schooling me man.
thanks guys. ill keep an eye on the junkyard for an exploder rad
