will these wheels fit on my ranger?
I personally don't know off hand but I know how you could check. You should be able to pull up the stock tire size on Discount Tires or the Tire Rack websites and see what backspacing and such is for a Flex/Escape/Etc. Then match it up with the information in the Tech Library for your RBV.
im not worried about the tire size its more about backspacing. ill check tirerack
Bolt pattern is good but all the vehicles listed besides the Ranger are FWD. Look elsewhere.
looks to be close to the style on the 2008 Explorer which will fit the Ranger ,but they due cause the tire to be closer to the frame due to back spacing
will fit with spacers to clear the front hubs. rears should be fine.
