Will these fit
I would have taken measurements. Then you could figure fitment without the new tires.
I thought so. So whats the largest size tire that would fit?
Also, I could just make a coil spacer by welding up some washers right?
Whats the highest I would want to go doing that, or should I just buy some spacers?
If I would need to buy spacers, would the tech library article about factory F-150 spacers work with a 3rd gen?
I'm sorry about asking a lot of questions, but as many of you know I cant afford tires.. and I found a cheap(ish) set of 31's.
I might end up going with a smaller tire anyway, depending on how much its going to cost to ready the truck for larger tires.
http://www.1sourcemfg.com/ these are much better than washers and they are the cheapest i could find........
I have a 92 2wd no/lift stock xlt just grabbed some 31x10.50x 15 goodyears on
wheels off a 90s jeep cherokee rims fit tight up front rubbing on the inside plastic
fenderwell . they are wayyyyyyybig on a stock truck .....didnt say they were perfect
fit RUBBING UP FRONT ON FENDERWELL thats it.
$$$$$50.$$$$$$$$$$$$$$$ducks
