- Aug 6, 2007
- Age
- 49
- Berrien Springs, MI
- My credo
- If you can't go through it or around it, then go over it.
I posted the same question kinda in alternative fuels. would LP conversion with a turbo say 10 psi boost on my 2F?
stock config
4.2L 165 hp @ 3600 210 ft/lb @ 1800. Added 3* advance cam timing.
if I do the LP I want to switch back and forth between gas an LP so I need a turbo system that will not only work with the carb but with the LP. what you think?
stock config
