Try to add gas or spray quick start into the intake, then crank, if engine fires then dies fuel is your problem.
If it doesn't fire then spark is the issue.
For fuel:
Ford computer turns on the fuel pump for 2 seconds each time the key is turned on.
Fuel pump is loud not quiet, can you hear the fuel pump coming on?
If not, then look in the Engine compartment Fuse box, there will be a 30amp Fuel Pump fuse, check it.
There will also be a Fuel Pump Relay, it should "click" when key is turned on, and then softer "click" 2 seconds later, there is a relay next to this one that will also "click" when key is turned on, the EEC Relay, but it won't "click" again until key is turned off.
If fuse is OK and Relay clicks then your new fuel pump is probably bad.
For spark:
get one of the old spark plugs and hook it to #1 wire, I use a jumper cable to hold the spark plug with other end on battery ground, but you can just set the spark plug against a metal part so you can see it from the cab and crank the engine, bright Blue spark is what you want, yellow is a weak spark.
And obviously no spark would be bad, and what's wrong.
Could be TFI module or bad wires for the TFI module, TFI test and info here:
http://www.therangerstation.com/tech_library/TFI_Diagnostic.shtml
