83rangerfirstrebuild
Ok I bought a p.o.s. I know that now but i don't know what to do know I bought an 83 ranger with the 2.3 in it. It ran rough when I first got it smoke coming out of the exhaust and smeeled bad of gas so I replaced the head with a rebuilt one came with cam and everything ready to go I also got a rebuilt carburetor. I've also put on a new computer new iac valve the thing on the side of the carburetor new water pump new alternator plugs and wires and battery. But here is what it does whenever I first put the carb on when it is compltely empty of gas the truck will start up and run great for about 5 minutes then it just fades out starts spuddering and choking gas startsshowing up under the carb and then it dies with a puff coming back out of the carb any suggestions on this problem I'm out of money so a simple fix would be great I've already changed so much it has to be something stupid doesn't it. Oh yeh no cat conv. Just a glasspack nothing to get clogged also after it quits running it will not start again well if you hold down on the pedal it will sputter and shake but will not rev up any I'm stuck
