bobbywalter
TRS 25th Anniversary
Ugly Truck of Month
- Aug 9, 2007
- woodhaven mi
- Automatic
- Total Lift
- sawzall?
- Tire Size
- 33-44
- My credo
- it is easier to fix and understand than "her"
while that is true about the stock wheels...its rarely done and when done not without issue rub wise in most cases.
but more of an issue is actual miles driven and the conditions driven in....where sasquatch and junkie puts on the same amount of miles in 5 years that i do in less then one and likely at nearly half the speed the majority of mine were done at. in harsh mixed driving with any moderate load the bearings are certainly high maintenance...especially with the offset i was running.
i feel it would be a safe bet that if i had run the 35's on factory wheels i likely would have doubled my bearing and rotor life. except for the swampers...the 15 35 15 would not workout with stock wheels...but i dont like runnin them down the road anyway and only run em if i had too due to job conditions.
now that i have more open road verse stop and go as i live way north, a d35 would be real livable.
so really no hard fast rule in my eyes besides the fact the bearing setup is defiantly weak for 35's on a daily driver if your a set and forget kind of person that does not do your own maintenance.
