will it fit?
js88420
86 & 99
i have an 86 ranger with a 2.9.... the motor is no good. i found someone with a running 1993 3.0 motor trans computer wiring harnes and accesories.... ac, alt ect... it really cheap $200. is it worth it to do the swap? how hard is it to make it all work? what should i do?
anything is possible if you have enough time but is it worth it?... not really...
if you look up 3.0 swap on this site youll find more info on it . its NOT imposible as ive seen more then a handfull of people do it . do what you gota do ! and if you have a good rbv with a bad engine and a good engine trans combo then Make it Work ! :icon_welder:
