will a 4.0L bolt in to a 95' 2.3?
tsimmons21
Dallas, Texas
i've been told it will, without having to replace axles and other components, would like your opinion.
Yes it will, you will need the 4.0L motor mounts and a trans, the 2.3L trans will not bolt up to the 4.0L, and you might need a driveshaft, but the rangers came with 4.0L's since 91, so all parts are readily available...
SVT
Don't forget a wiring harness! If you can find a 4.0 from a 95 or newer ranger with the harness and trans you'd be alot better off than trying to install an older one. Best bet would be to find a donor vehicle with everything you need.
