Will a 3.8 v6 bolt up to a m5r1 transmission in a 99 ranger.
crazyman2006
Alabama
I have a 99 ranger 2.5 manual and an 02 mustang 3.8 automatic. I would like to put the 3.8 in the ranger. Will the 3.8 bolt up to the m5r1 manual transmission? I know I will need a flywheel and clutch.
there are 2 different bell housing patterns for the 3.8
small block, & FWD
the FWD is the same as a 3.0 Vulcan
neither match the 2.5
small block, & FWD
But does the FWD 3.8 bolt into longitudinal mount? At least the RWD version bolts in like an Explorer V-8.
good question.
I had a 3.8 block from a '95 taurus and tested the bell housing.
don't remember what the motor mounts looked like, and disposed of that block a few years ago.
EDIT: found info that says they are different
and... there are 10 different 3.8 blocks
Amd tou can always make a mount to fit
