will a 2000 master and slave cylender work on a 95?
keith0486
mass
well i got a 95 rangs and the clutch blew on me as long with the clutch master cylinder and slave cylinder. well what i was woundering is if i could swap parts from that car to mine?
The masters are interchangable I believe. Got to napaonline.com and check to be sure, compaire the years and parts.
Dave
Well like I said, I went to Napa on line store and looked for him. The master cylinders for both the 95 and 2000 have the same part number. Your ebay listing shows a F2xxxx which is an early 90 Ford.
Dave
Master- no.
Slave - yes.
Keith,
How did you know your master/slave cylinders were bad? What were the symptoms? I have a post I included the link to below. If you could check it out, I'd appreciate it. Anyway, here are my thoughts on your post:
I'd call the following places and tell them you need a master & slave cylinder for a 1995 and a 2000 Ranger. These are online ford dealers. Tell them you want to order the parts online and they'll give you the part numbers of everything in question...If they match, you'll know your answer. You can also check www.Rockauto.com to see if their part numbers match up. Good luck!
Dave
http://www.oefordparts.com/ - I found these guys to be the nicest and the cheapest!
http://wholesale-ford-parts.com/
http://www.trademotion.com/
Here's my post:
http://www.therangerstation.com/forums/showthread.php?p=368802#post368802
