Widest wheel on fw sas
bIIjr
southern pa
Can I get away with 10 in wheels on my bII sas ? I know I seen in here before don't have time to look through everything at the moment and a set kinda fell in my lap
That greatly depends on what tire size your running, Rim diameter, what backspacing the wheels have, AND what axle (well, technically brake) setup you're running.
It would be complete axle set up from a 79 150 so d44 front and 9 rear I'm assuming they are 3.75 - 4 in offset with 36 in swampers there is no wheelwell or fenders in the front wheels would be 15's
3.75 backspace is what I'm running with a 10 inch rim there's about 1-1/4" between the rim and the tie rod end and I'm running 7/8" heim joints and I have about 1/2" between the brake caliper bolt to the rim. And I haven't had any problems.
