explorersportster
I see a lot of info on 44s and 60s, but not much on the 50. Is it not a good axle? Just don't know much about the axle itself.
Dodge used a D50?![]()
I had a dana 50 ttb under my fullsize with 39.5 in boggers and a built 351w for a little over a year and ran the balls off of it.The only problem i had was wheel bearings.
Thats strange, a D50 TTB uses the same wheel bearings as the D60 Yes they use the same wheel bearings and lockouts, I could not keep the wheel bearings tight no matter what i tried.
the TTB was the one I was curious about, I have a line on one for cheap but I'm not going through the hassle for minimum gains
