why does the d/s drum brakes on a ford explode?
alaskan155
washington
any answer...
My 2000 ranger just exploded on the driver-side
my f250 did last year in the e-brake part(pin backed out)
and a few years ago my buddy with a stock 2000 ranger 3.0 did the same thing....
i have even lost a tire on the D/S rear flat towing my old Bronco II:icon_rofl:
ALWAYS the driver-side rear.... so WTF?:icon_confused: and this is probally in the last 5-6years...
Not sure to be honest...my last deal with brakes involved the driver side brake cylinder leaking and for some reason I didn't get to replace it properly. I ended up plugging the line to that side after changing the cylinder...think the bleeder screw was pooched or something like that...
Drove it for about six months with only the passenger side rears working (and the fronts)...didn't even get to pull the new cylinder out of it before I sent it to Ranger Heaven...
But my Tempo rear brakes on the driver side blew out the line...plugged the master on that line and drove for six months before replacing the line...
Crazy. In the time I've been around TRS (13 or so years now?) I've never heard of this. Subscribing to see what others have to say...
I've never had good drum brakes on a Ranger. I've replaced everything but the backing plate before and they still weren't right. That's why I want my disc-braked 8.8 under the truck so bad....
On my old 73 high boy I had a stay pin break once. The pin the goes through the backing plate and holds the shoes. They entire system came apart and ground about a 1/2 deep groove, from the rivets in the shoes, in the drum. I replaced all the parts and new drums and never had it happen again. It was on the driver side as well. Only issue I have ever had. I have had my Ranger since 92 or so, and my Explorer since 06.
Well, this is an interesting thread.
I have or had 4 Rangers. Starting in 91. The only thing I have ever experienced on rear brakes is taking a look every 30K and doing maintenance every 60/80K. I push pedal and they keep the rear back there.
Unlike the old F series, when you really got on those brakes, you could find the rear passing the front.
:D:D Yup. I replaced everything between the backing plate and th drum. I learned to to keep the rears a tad loose in the adjustment. Stopping aint worth a thing if you're sliding backwards .
Make sure the E brake cables are free. New hardware kits are cheap. Take off both drums, but only do one side at a time. :D
Strange indeed. Had 10 RBV since 84 and never heard or seen this before. Usually very trouble free once they are working.
Dave
300000+ and haven't encountered anything like this. 89 F250 never had problem either except when seal leaked and shoes had to be R&Rd (warranty). Been around lots of fords never saw this either from old to new.
Move over, alaskan.....It happened to me couple months ago at 147k. I figured the star wheel started to spin & then B O O M-
