Why diff HP 3.0 V6?
Ger42
Plantation FL
150hp @ 4750 RPM (2000 - 2001)
146hp @ 5050 RPM (2002)
154hp @ 5200 RPM (2003 - 2004)
Why is the 2002 lower than the 2001 or 2003?
Gerry
Or just different sources for the info. Where did you get the numbers?
Without the author listed on the page, I would guess the numbers were just pulled from different publications. The engines probably produce the exact same output.
i think another reason is because i think after 01 they put on a plastic upper intake therefore lowering intake temps. the 02+ should have just a little bit more horsepower than later models.
