- Aug 7, 2007
- Opelousas La.
- Manual
An electronics instructor that doesn't know you need AIR to burn hydrogen?."
OK Genius.
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
OK Genius.Did you ever stop to think about what the two components of water are? You don't need air
to burn hydrogen, you need oxygen. Where did the oxygen go that was combined with the hydrogen before they were separated? Did it just vanish into thin air? Or is there a tube that draws it off separately from the hydrogen?
Can we name this whole area of TRS the "MAKG says your wrong" Forum?
Where did I say it was an oxygen generator? And placing your hand over the inlet tract seldom results in a complete seal. Plus how much oxygen does it take to burn hydrogen too? I don't know, but could there be a chance there's enough oxygen left to burn the gasoline? It takes 10 to 16 parts air to burn gasoline, but not all the air is comprised of oxygen. I do know that the introduction of pure oxygen is something you really don't want to do with an uncontrolled fireSo you're saying the point of this "HHO" crap is an oxygen generator?
You get only enough oxygen to burn the hydrogen you made (assuming no leaks). That's it. You have none left over for the gasoline with the air intake covered over.
Which means you're "idling" the engine with the equivalent of a few-hundred watt electric motor. A quick look at the (MUCH slower) starter motor will show it draws quite a lot more power than that.
A working engine will ALWAYS stall when the air inlet is covered. If it doesn't, it's not working, and the "conclusions" are KNOWN to suffer from hidden variables.
That there might be some effect on worn out COMPRESSION IGNITION engines might have something to do with compression loss and modest changes in combustion temperatures. But spark ignition engines need to be next-to-destroyed for compression loss to result in misfires, and hydrogen won't replace the burnt valves or broken piston rings.
If you ARE burning the hydrogen, you didn't do anything.
It takes exactly as much oxygen to burn the hydrogen as you made from the water. Maybe a little more if it leaks. This is one of many reasons why it can't possibly work. There is NO chance there is any left to burn gasoline AND all the hydrogen. If you're not burning all the hydrogen, it's a (bad) oxygen generator that displaces fuel with hydrogen. If you ARE burning the hydrogen, you didn't do anything.
And it ain't pure oxygen.
And I can make an airtight seal over a tube with my hand. You can't?
I'm thoroughly amazed at how badly one has to understand the most basic chemistry in order to think something like this might have the slightest prayer.Now this statement smacks of someone who's too big for his britchesAnd tells me you've never tried any of this stuff to prove yourself wrong. It's akin to someone from the 1800's saying man will never be able to travel to the moon.
If it took one part oxygen to burn two parts hydrogen, then water would be flamable.
And why wouldn't the oxygen produced not be pure?
Most ideas thrown out as stupid are indeed stupid. Name ONE invention made by an uneducated redneck
READ what you said -- you asked if there was oxygen left over. What the F did you mean if it wasn't that there was, well, oxygen left over? And pay attention in school. And especially pay attention to your own claims.
Name ONE invention made by an uneducated redneck, without the assistance of someone more educated.
The wheel.
The automobile. (Henry Ford's family were farmers and so was he, making him a redneck)
