- Mar 15, 2009
- Tallahassee, Fl
sounds like A: compression was too high from carbon buildup, or B: you got too much sea foam in it (ran it tooo rich)
Nope, pure distilled Chuck Norris. He musta just got turned around in there with his roundhouse kick.
as i BELIEVE it is a centrifugal pump, so it would more or less still pump the same direction in reverse (even though it would not work nearly as well) same goes for your water pump, it should still pump coolant the right direction
A centrifugal pump will not flow anything if it runs backwards. The theory of the pump is to fling fluid out from the center to the case/ housing
