Taking in technical information based on which answers you like?
What is wrong with this attitude?
Nebraska not someplace you need to worry about overheating?
that's another one I have a problem with... after driving across
Nebraska in 105degree heat... in SEPTEMBER!
I gotta wonder what nebraska you live in...
also which END of Nebraska because last time I checked
Nebraska isn't "flat"... it's 4500ft higher at the western end
than it is at the Omaha end.... and elevation isn't only a killer
of performance but of cooling system efficiency as the air gets thinner.
It might not sound like much but the air is 5% thinner in Sidney than it is in Omaha or Lincoln.
You don't build for the average conditions but the worst conditions.
would you only protect your engine with antifreeze to 0degF
because there aren't that many days where the temp gets to -20F? I've only driven across Nebraska twice in winter but I've seen -33F on the trip...
Yeah, most days you get away with it, it's the one day you don't that will make you relly regret previous decisions.
If the price of a gasket set bothers you get it off ebay...
but don't forget a set of headbolts, these are "single use"
As for the "difficulty" of replacingthe head gaskets?
You already have to do 90% of the job as you MUST replace
the lower intake and the exhaust manifolds anyway...
It's literally 16 additional bolts (8 bolts per side) that you are
whining about changing... frankly a head gasket set includes
an intake gasket set that you'd need to change the intake
that you have NO choice about changing.
Getting the valve covers and intake off is 90% of the battle
in doing head gaskets.
Doing it right is ALWAYS cheaper than doing it over.
AD
