Soon I am going to have to swap in a new auto tranny(4r55e) in my '96 B4000. What would be the best way to do so?
-Pull the motor+tranny together?
-Or just drop the tranny?
unbolt the passenger side of the cab a little, jack it up a few inches, then take the shifter up, and get the top bolts with some extensions, and the side bolts from the fender wells if you have to.
if you jack the cab up a bit, you can clear the exhaust, i have a 3" body lift and mine clears without jacking up the cab no problem.
def unbolt the t-case first, its heavier then you may think!
remove the starter, so you can unbolt the torque converter if its auto
Wow, I'm surprised it didn't do more damage! It sure makes for a good story though haha.
