ncsdaonex
- Dec 5, 2008
I bought a wrecked truck and im not sure if the engine is ok. The raadiator has a hole in it. The oil cap has white foam on it like u see when oil and water mix. Also I added antifreeze and when it leaked out the radiator it was a bright whitish green so idk if the oil cap was just condensation and if the radiator was a similar thing but I drained the oil after seeing this and it was clean only oil no mixture so i put the oil back in the engine so if the oil is clean does that mean everything is probably good?
