White fire? How are you seeing this white fire?
Did you take out a plug and ground it to the valve cover while cranking? Your spark should be blue, typically, but it's actually hard to see in daylight...
Does the truck start and run or just crank and not fire?
While I agree it could be the coil, you can test that with a voltmeter...should be something like 12,000 volts, but if you search Google you can find several videos on how to test the ignition system...including testing the resistance in the wires...and whether you are getting voltage at the distributor and plug (insert the probe into the end of one of the plug wires...crank if no voltage there).
Maybe add a bit more information as to what it is doing or not doing and we can assist a bit more...
