which trans
sparkey
nc
I have aToyo Koygo 5-Speed behind a 2.9 its more of a daily driver and in need of repair. My questions is which trans is better the Toyo Koygo 5-Speed or the fm145 fm146 it is a 4x4 if it matters just wondering which you all prefer for what ever you use it for
All the ones you just mentioned are boat anchors compared to the M5OD-R1. Search the forums here http://www.therangerstation.com/forums/search.php and that should give you anything and everything that you should need. Check it out there and if you happen to have some after searching by all means ask away........but search first.
