which Skyjacker 6 inch?
v6Ranger
Which skyjacker 6 inch should i get for wheeling? there is one that says it will fit 34x12.5 for max tire size and another 6 inch that says 32" max. I want to run 33x12.5 with the lift and do mild wheeling with it. So i want the kit that will have the most articulation, i realize its not a straight axle but i want some decent flex out of it
If I remember right the better kits come with new rear springs instead of blocks. And the higher stage kits will give better articulation. Also the better lit comes with shocks.
James Duff and a superrunner or skullcrusher steering setup. Check out my thread "at a cross roads".
It might not be a setup for you if all you do is mud, because you don't need the flex as much, and heim joints don't care for mud as well. But the best flexing bolt on kit is Duff. AFAIK skyjacker doesn't sell kits with shocks but likely provides a part number for the appropriate ones.
