Where to put my sub
Syd
Lisbon
anyone with a regular cab got a system in their truck somehow?i want to get just one mtx 10inch in somewhere but not sure where to put it at. Any ideas?
I put my JVC Arsenal 10" behind the passenger seat. I had to take out the Jack though. Its a tight fit but i can get a picture of it if you need it. since your truck is a little older i think the regular cab is a a bit smaller cant remember how much but. Mine was only a pain because it had a deep mounting depth.
i have a 94 regular cab and im putting a TB 8" in. The guy im buying it from told me to mount it behind the driver seat and run the port out of the side behind the passenger seat.
i put an 8" sub behind my passenger seat. i had to remove the bracket that holds the jack and the bars. i just threw the bars under the passenger seat and the jack sits next to my box. i beleive the mounting depth on mine was about 4.5". youll have to build a wedge type box for it.
i have 1 10 alpine s-10 be hind my passinger's with a what a old school s10 amp was not easy to fit.. the problm i ran in to was the death of th speacker.. i had to make one... fist have to remove the bracket that holds the jack and the bars down then maser the death and highth mine is a wedge type box. the only way your going to fit it (sory i suck at spelling) mine is 4 3/4 top and 7 3/8 botum (have to nouch the back of box for the lit under the window then the speacker fit just under it) i fulled mine with foam to make the speacker thang the box is biger then what it is... it hit's hard most pep's thank i have a 12 in there the way it hit's....... but that what i did so i hope that help's you out some how...............GL
I'm doing one with a 8" between the seats you can check out the one that I posted earlier 98 ford ranger with custom install. I will post when completed.
