Where to get TFI coil mounting bracket?
1BadRS
pinehurst, nc
I'm in process of putting my 84 back together. The previous owner had used a canister type coil and I'm going to do the duraspark with the TFI coil.
My truck is not equipped with AC and the canister coil was mounted onto the heater box assembly. I'd like to do the same with this TFI coil. I have the new coil, just no bracket. Anybody know where you can purchase one? Also I'd be interested to see any pics you may have that did the duraspark with the TFI coil.
Thanks
:icon_welder::icon_welder::icon_welder: <--- Then you will have exactly what you want. If recall, my 84 actually had the coil mounter on the driver's side fender well.
If the square mount in not on the drivers fenderwell you can get one at the bone yard, and might as well take the coil with it if it is still there, from any tfi ford ignition 1983- 92 I believe will work.
