Blackducati750
I have a 2002 Ranger with the 2.3L . The tach needle sometimes "gets stuck" even though the engine revs are getting higher. Also, sometimes the tach needle jumps +/- a few hundred rpm when crusing at a steady rpm. The engine DOES NOT run any different when the tach starts "going crazy."
Where does the tach get it's signal from? The coil or the crank/camshaft sensor?
The coil only has about 20,000 miles on it.
The truck just hit 240,000 miles and runs like a top except for this tach problem and a small misfire.
Any help would be great.
Thanks!
Thanks!
